Aux cooler
Old Mar 30, 2013 | 10:15 AM
Tony5.9's Avatar
Tony5.9
Default Aux cooler
I order a new cooler to help my trani get cooler but what fitting do I need to splice the new cooler lines to the factory rubber cooler line so it's dubbled cooled
Old Mar 30, 2013 | 06:29 PM
moe7404's Avatar
moe7404
while doing that check this out.
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com.au/magna-fine.html*
2. for other sizes wix 58964 5/16 tube size reff:http://www.wixfilters.com/filterlook...sionfilter.asp
Old Mar 31, 2013 | 04:50 PM
dhvaughan's Avatar
dhvaughan
i kept mine simple and used worm clamps and no fittings. i used a tubing cutter to cut the hard lines at the frame and slipped the hose over the lines. i also cut the quick connect flares off the radiator pipes and slipped the hoses over them also. if you want to be more precise, get some 3/8 inch compression fittings and barbed connectors for the hoses.
https://dodgeforum.com/forum/2nd-gen...ter-added.html
Old Mar 31, 2013 | 05:34 PM
Tony5.9's Avatar
Tony5.9
Question what r those fitting called that have 3 outlets
Old Mar 31, 2013 | 05:46 PM
Tony5.9's Avatar
Tony5.9
What is the point of the filter doesn't the tranny have 1 internally
Old Mar 31, 2013 | 05:53 PM
Tony5.9's Avatar
Tony5.9
Is this wright part number 2210 duralast power steering filter
Old Mar 31, 2013 | 05:57 PM
guzman's Avatar
guzman
Default filter
Answer: The wrong one.....
Neither one of those links in your post work for me so can't check out what your looking at.
Old Mar 31, 2013 | 06:06 PM
gdstock's Avatar
gdstock
This isn't going well. OP, search Aux Trans Filter here. Lots of threads on it.
Old Mar 31, 2013 | 07:38 PM
dhvaughan's Avatar
dhvaughan
are you talking about a T fitting. as in the kind where you put a trans temp sensor in the hot line.
http://www.summitracing.com/parts/bmm-80212
Old Mar 31, 2013 | 07:43 PM
dhvaughan's Avatar
dhvaughan
no offense intended, but i'd be afraid to put a power steering filter on the transmission line without knowing if it had a bypass valve.
if it doesn't, and if it stops up... it'll kill your $2000 transmission.
http://www.autozone.com/autozone/par...ier=13909_0_0_
