Rear Speed Sensor Help
Old Apr 4, 2013 | 01:09 PM
Ramman18's Avatar
Ramman18
Borg-Warner.^^^^ I put one in last year and so far it works great. It wasn't the cheapest one they had.
Old Apr 4, 2013 | 02:03 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I'll use BWD in a pinch on Sunday, but I'll use Standard Motor Products or Mopar only otherwise. Right now I have a BWD coil installed , and I'm shaking in my (boot) every time I drive it.
Old Apr 4, 2013 | 08:53 PM
bulldodgemoe's Avatar
bulldodgemoe
well know i know what to do to fix mine now. thanks. my lights will at times come on and some times they wont
Old Apr 8, 2013 | 12:28 AM
hardhands's Avatar
hardhands
On another note. My lights randomly come on, then I shut her off and they don't come on after firing up again. I noticed when my lights (BRAKE & ABS) my speedometer would work as it should. So my question would be, what would cause those lights to come on now? Thanks for reading.
Old Apr 8, 2013 | 11:02 AM
zman17's Avatar
zman17
I've seen plenty of time's when the sensor is bad and the speedo still work's.
Old Apr 8, 2013 | 12:28 PM
Ramman18's Avatar
Ramman18
My understanding is the speed sensor is for ABS and the speedometer sensor is in the transmission. At least that's how my 99 is setup.
Old Apr 8, 2013 | 12:39 PM
zman17's Avatar
zman17
Not true, it's the sensor on top of the diff.(ABS and Speedo on a 99) But, there is also a sensor on the tail shaft of TC or on the tail shaft of tranny if 2wd on some. They did away with 2 sensors in 98, but I have seen some 98's and 99's with both. Either way, the one on the rear diff still also controls speedo.
Old Apr 8, 2013 | 12:45 PM
Ramman18's Avatar
Ramman18
Is my manual trans different? When the diff sensor died on me, the speedo still worked.
Old Apr 8, 2013 | 12:51 PM
zman17's Avatar
zman17
That's because when that sensor goes bad, it does not alway's effect the speedo. I've seen this more than once or twice. Can't tell you why. Yes, maybe the manual is different, I'm just going by what I know about automatics.
Old Apr 9, 2013 | 11:26 AM
Ramman18's Avatar
Ramman18
Ok, cool. I'll look it up sometime.
