Engine Hiss
Old Apr 3, 2013 | 02:43 AM
Thejudge02's Avatar
Thejudge02
Default Engine Hiss
95 ram engine misses at idle speed and makes a weird hissing noise when I turn the truck off.
Old Apr 3, 2013 | 09:19 AM
Any codes?
Old Apr 4, 2013 | 03:40 AM
Thejudge02's Avatar
Thejudge02
No I noticed it was running rough when stopped at a redlight a few weeks ago. It has plenty of power while driving just starts to studder when at a redlight. The hissing noise sound like its losing pressure or something. Gonna change the cap and rotor this weekend and see if it helps at all.
Old Apr 4, 2013 | 07:18 AM
dhvaughan's Avatar
dhvaughan
if the AC has been on, a hissing sound from the AC system is normal.
if it's not AC, then its likely from the cooling system. a little bit of blowoff from the radiator cap into the overflow tank is normal. cap is something like 16 psi. if you have a coolant leak elsewhere, it might be making some noise. any coolant on the ground?
Old Apr 4, 2013 | 07:21 AM
dhvaughan's Avatar
dhvaughan
plugs, cap, rotor?
vacuum leak? that could explain a hissing sound when running, but not when engine is off.
if you suspect it might be something serious, you should rent a compression tester from the parts store and check it to rule out major problems. you can check it while you replace the plugs.
Old Apr 4, 2013 | 06:02 PM
Ewaters's Avatar
Ewaters
Chech your EGR valve. I had a problem very similar to yours. EGR valve was opening to early. Possibly the Temp sensor for ECM. I unlugged the vacuum line to the EGR valve and problem went away. Truck is parked now while I replace the Dash and entire instrument panel. I will trouble shoot the rest after this.
