Thermostat housing?
Old Apr 4, 2013 | 11:11 PM
Spillage's Avatar
Spillage
Default Thermostat housing?
Cast aluminium or steel?
Is there a preference... benefits/disadvantages of each?
Thanks
Old Apr 4, 2013 | 11:37 PM
gdstock's Avatar
gdstock
Either will work. OEM is cast aluminum I think.
Old Apr 5, 2013 | 04:41 AM
guzman's Avatar
guzman
I replaced my metal one with the aluminum one=no rust.
Old Apr 5, 2013 | 07:10 AM
dhvaughan's Avatar
dhvaughan
the stock one is steel. i recall grinding the "front" tab off and it was stamped/drawn steel, not aluminum. steel would be cheaper.
as said, either will work.
Old Apr 5, 2013 | 07:19 AM
Spillage's Avatar
Spillage
$10/$7... either way, they're cheap enough... ali it is.
Old Apr 6, 2013 | 12:03 AM
gdstock's Avatar
gdstock
You are correct. As soon as you referenced the tab, I remembered. I have pulled too many off too many vehicles since I had it off the Ram about a year ago or so.
