Relieve fuel pressure
Old Apr 6, 2013 | 08:06 PM
Blue Mopar01's Avatar
Blue Mopar01
Default Relieve fuel pressure
Does anybody know of a good method to remove the fuel pressure in fuel lines when I remove the line from the fuel rails? I read about pulling the fuel pressure relay, let the truck run till it dies and then there's no more pressure. I'm doing my plenum that's the origin of the question.
Old Apr 6, 2013 | 08:09 PM
dogbosser14's Avatar
dogbosser14
If i am rembering right and putting 2 and 2 together. on the drivers side there is a pressure release noosle that you can hook up to a fuel pressure tester... u can push a screw driver down there and it should relieve the pressure. just beware on the spray of fuel.
I think i am correct but not sure...
Old Apr 6, 2013 | 08:11 PM
stewie01's Avatar
stewie01
You could pull the relay or fuse for the fuel pump, then as dogbosser14 said use the schrader valve to purge the line
Edit:
Don't forget the fuel line disconnect tool when you start tearing her apart
Old Apr 6, 2013 | 08:13 PM
dogbosser14
Edit:
Hey thanks for the technical term couldnt think of it! =]
Old Apr 6, 2013 | 08:16 PM
Blue Mopar01
Ah thanks guys! I have the removal tools, gunna go start labeling stuff and tearing her apart.
Old Apr 6, 2013 | 08:43 PM
gdstock's Avatar
gdstock
Post up photos or it didn't happen!
Old Apr 7, 2013 | 09:01 PM
Blue Mopar01
I'll have pics up later tonight!
Old Apr 7, 2013 | 09:24 PM
Blue Mopar01
Am I doing something wrong? I pulled the fuel pump relay out of the PDC, cranked over my truck, and pushed in the schrader valve but no fuel sprayed out
Old Apr 7, 2013 | 10:04 PM
dhvaughan's Avatar
dhvaughan
pressure has bled down from truck being off - its normal.
Old Apr 7, 2013 | 10:15 PM
Blue Mopar01
K, so I'll be safe to unplug the fuel lines correct?
