Towing help
Old 04-08-2013, 05:36 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
Originally Posted by Ish315
If I turn overdrive off even without camper it turns 3000 rpm at 55 mph, what do you mean +1 on new cat? yes 5.9 never had compression ck... 9700 miles facrory tire size
Towing must be done out of O/D really important with the size of load you are towing, get used to it. Time for a comp test, these heads like to crack between the valve seats.
Edit; The death flash (pcm down tune from ma Mopar) is not helping one bit, look at getting a tuner of some flavor to get rid of it.
Old 04-08-2013, 05:40 PM
Ish315's Avatar
Ish315
Ish315 is offline
what should compression be?
Old 04-08-2013, 05:42 PM
merc225hp's Avatar
merc225hp
Min is 100psi as per the fsm, Me I like to see 140-165 psi per jug. Start with number 8 cyld as that's the jug that likes to go south.
Edit; I forgot welcome to Df! Lot's of good info here just need thick skin thats all. lol
Also you can DL the FSM from here.https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old 04-08-2013, 05:45 PM
Ish315's Avatar
Ish315
Ish315 is offline
Thank you! Oye heads
Old 04-08-2013, 05:48 PM
merc225hp's Avatar
merc225hp
Yep fun eh! About 15hrs work to change out both heads. If they are bad don't get a reman head look at Odessa or Cific heads.
Old 04-08-2013, 05:57 PM
Ish315's Avatar
Ish315
Ish315 is offline
will do thank you!
Old 04-08-2013, 07:03 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
150 is good. As long as they are all withinh ~10 psi of each other they are alright.
Leave OD off. Max torque is at about 3400 RPM anyway
Old 04-08-2013, 08:07 PM
redneck_ram's Avatar
redneck_ram
redneck_ram is offline
fwiw, i towed a jeep GC, last year with a tired 5.2(318) and maintained 65-70 no problem. o/d was off too.
total weight was a little over 7k.
Old 04-08-2013, 09:43 PM
Ish315's Avatar
Ish315
Ish315 is offline
Thank you I will take all the wisdom I can get!
Old 04-08-2013, 10:59 PM
gdstock's Avatar
gdstock
gdstock is offline
3000 rpm sounds kind of high for 55 mph. Were the 4:10's original or changed out at some point?
Someone else running 4:10's may post up what their rpm range is. Are you sure you are getting all gears in trans?
Quick Reply: Towing help
