what damage will a bad front axel u-joint cause?
Old Apr 11, 2013 | 05:15 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
You'll need a 14mm 12 point x 1/2 drive impact socket. If loosening them doesn't break a regular POS socket, torqing them back to spec might.
Old Apr 15, 2013 | 10:33 PM
  #22
smoky614's Avatar
smoky614
thanks for yalls inputs. i got one side down and now one to go!! but go figure when i was pullin it apart i noticed the tie rod, wheel bearings and ball joint are all goin to s***. just my luck! Id imagiane the other side is just as bad. Looks like im gonna have my hands full and my pockets empty for a little while!!!
Old Apr 16, 2013 | 09:28 AM
  #23
You own a dodge.... situation normal.
Old Apr 16, 2013 | 11:23 AM
  #24
h3lzsn1p3r's Avatar
h3lzsn1p3r
it is fine till the weekend I have has some in the shop that the caps are barely there and it has 3/4 inch play
Old Apr 16, 2013 | 11:42 AM
  #25
Annihilator_X9's Avatar
Annihilator_X9
Dude, that's an awesome shortcut. I have to do this on mine and figured I'd have to take that all apart.
You guys rock!
Old Apr 16, 2013 | 01:10 PM
  #26
h3lzsn1p3r's Avatar
h3lzsn1p3r
I do these 2hrs for both keep the bearing on and use the ball joint press
Old Apr 18, 2013 | 02:43 AM
  #27
Wh1t3NuKle's Avatar
Wh1t3NuKle
Job well done!
