99 Ram 2500 vibration from rear when turning.
Old Apr 10, 2013 | 03:45 AM
kadetklapp's Avatar
kadetklapp
Default 99 Ram 2500 vibration from rear when turning.
Recently my 99 4x4 long wheel base truck has developed a low speed vibration when turning. Ideas? Rear diff was serviced less than 6k miles ago. Does not have limited slip.
Old Apr 10, 2013 | 10:21 AM
Bearing going bad? Hear any odd noises? Lug nuts tight?
Old Apr 11, 2013 | 04:28 PM
kadetklapp's Avatar
kadetklapp
I replaced outer axle bearings last summer. I've only put a few thousand miles on since. There is a moan or groan but its not loud and both the vibration and sound are intermittent and only at low speed while turning.
Old Apr 11, 2013 | 04:35 PM
aofarrell2's Avatar
aofarrell2
Check u-joints on front axle and all driveshafts. Had the same problem - all the needles had fallen out of my front axle ujoints (factory with 125K+mi on them).
Old Apr 11, 2013 | 05:52 PM
kadetklapp's Avatar
kadetklapp
Thanks for the tip. I crawled around and looked and the center support bearing looks pretty dry and I don't see a way to grease it or the U-joints so I'm wondering if it's time for replacement anyway. I was also wondering about the slip joint in the rear shaft.
Old Apr 11, 2013 | 05:56 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
http://dodgeram.org/tech/Quiz/axle_noise.html
Get an angle finder and check your pinion angle and angle off the tcase.
Check your ubolts to see if loosened up. Need to be 120 ft-lbs.
