Check valve delete questions
Old Apr 11, 2013 | 06:05 PM
lbzrango's Avatar
lbzrango
Default Check valve delete questions
Hey everyone, my brother has a 99 ram sport 318 auto
His trucks been acting up lately not idiling in park or reverse when it's cold but fine when it warms up!
His truck got a new "used" tranny installed awhile back we did and I was thinking maybe the check valves were clogging up causing this issue ?
We were just going to cut the check valves out with a brake line tool and clamp in some hose.
Any ways my questions are:
Pros and cons of deleting the check valve this way?
Could the check valve be the problem ?
Old Apr 11, 2013 | 06:23 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I doubt it's the problem, but there are no cons to deleting the check valve. And there is only one check valve.
Old Apr 11, 2013 | 06:58 PM
lbzrango's Avatar
lbzrango
Alright I'll probably still do it either way,,
You have any idea what it might be ?
Old Apr 11, 2013 | 07:46 PM
aofarrell2's Avatar
aofarrell2
Check the spark plugs, dizzy cap, spark plug wires, and rotor. Check and clean the IAC.
Old Apr 11, 2013 | 10:50 PM
lbzrango's Avatar
lbzrango
I've done all that already, I'm doing check valve and trying a whole other throttle body with iac and throttle position
Old Apr 11, 2013 | 10:58 PM
gdstock's Avatar
gdstock
Check for vacuum leak as well as the items referenced by beginningjockey..
