I have a 2000 dodge ram 1500 sport 5.9 and I was curious about how common this plenum problem is? At what mileage it fails? This truck has 138,600 miles on it, and how much it would cost to get it replaced at a shop? Thanks for any help
And this truck does not have the problem, I just wanna know when It usually fails, I bought it with 137,xxx on it, so do you guys think it's already been replaced? Thanks
Read the plenum sticky. The problem is symptom driven. If you have any or all of these symptoms, it has probably failed. Easy to check though. Look into the throttle body. Oil pooled = failed plenum (usually). Also use the search function for plenum. Thread after thread has been started.
