4wd indicator flickering
Old Apr 20, 2013 | 09:15 AM
DanAnderson's Avatar
DanAnderson
Default 4wd indicator flickering
I ave a 2000 dodge ram 1500. I had the tranny rebuilt. Truck drove great, then i had to put it into 4wd. I shifted back to 2wd everything seemed fine until i got to a stop sign. I took off from the stop sign, the shifting was erratic and the 4wd light was flickering. I took it back to the rebuild guy he plugged into a sensor under the dash found out it was a failing solenoid. He replaced the solenoids. the truck worked great until i had to put into 4wd then the same problem. I am baffled as is the rebuild guy. Any help would be much appreciated.
Old Apr 20, 2013 | 10:30 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Check this out, http://www.dodgeram.org/tech/repair/..._engagment.htm
