OBD-II Trouble Code: P0441
Old Apr 21, 2013 | 10:25 PM
wheels1388's Avatar
wheels1388
Default OBD-II Trouble Code: P0441
Has anyone had this code pop up for them yet? it doesn't seem major but just seeking out what everyone has experienced when looking for what the actual problem is. The code lists off a few different problems but, what has been your problem and any advise on how to fix and how easy it is? All help is warranted. Thanks!
Evaporative Emission Control System Incorrect Purge Flow
Read more at: http://www.obd-codes.com/p0441
Copyright © OBD-Codes.com
Copyright © OBD-Codes.comEvaporative Emission Control System Incorrect Purge Flow
Old Apr 22, 2013 | 01:25 PM
Ramingo's Avatar
Ramingo
check vacuum lines, if thats not the problem, then replace the purge valve.
Old Apr 22, 2013 | 05:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1... You need check/trace all the vac lines and also make sure the canister is not cracked.
Old Apr 28, 2013 | 01:43 PM
wheels1388's Avatar
wheels1388
Hey thanks guys for the responses. I will be sure to check this stuff out!
