fog lights
Old Apr 23, 2013 | 12:25 AM
szpilafam's Avatar
szpilafam
Default fog lights
So I downloaded the manual (thank you so much) However the electrical schematic I need for the fog lights is not there, matter of fact the diagrams are missing from 8W-50-4 thru 8W-50-7 anybody have these or at least can tell me where the fog light switch wiring goes? I got pin 1 brown/white (?), pin 2 black/orange (ground), pin 3 black/orange (also ground), pin 4 (empty), pin 5 orange (illuminate POS), and pin 6 light blue (?)
Old Apr 23, 2013 | 12:23 PM
Fog light switch goes next to the O/D off switch (on trucks with auto trans.) Should be a single connector hanging out under about the middle of the radiator that the F/L harness plugs into. (easily scored from a junk yard.)
Old Apr 23, 2013 | 12:33 PM
szpilafam's Avatar
szpilafam
I found this after some digging
1) Brown/White wire-Fog Relay #2 Coil; 2) Black/orange wire-Fog Switch to ground; 3) Black/orange wire-Fog Switch Ind to ground; 5) Orange wire-Switch Illum; 6) Lt. Blue wire-Fog Switch Ind power.
