Vibration
Old Apr 24, 2013 | 11:24 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
ware on the inside of the tire could be ball joint very unlikely probably a toe issue have it aligned if there is any bad front end parts then they will tell you because front end needs to be tight
the vibes are probably scalloping on the tires from misalignment
Old Apr 25, 2013 | 06:37 AM
James Most's Avatar
James Most
Default Vibration
Seems to be more from the steering/ front end. At higher speeds the whole thing rattles though.
Old Apr 25, 2013 | 07:26 PM
gdstock's Avatar
gdstock
Not sure, but did you not say the tire with the wear is on the front? Did you rotate and check again?
Old Apr 25, 2013 | 10:06 PM
James Most's Avatar
James Most
Took truck to shop. Ball joints are bad causing bad tire wear and u joints causing vibration. Had them do the ball joints and I'll do the u joints in a week or two and see if that helps the vibration
