truck will start but quickly dies without giving gas
Old Apr 29, 2013 | 09:41 PM
abdodge1500's Avatar
abdodge1500
Yes I probably should have used a better title than that, I was just in need of help fast, other than this my truck has been solid ever since I bought it
Old Apr 30, 2013 | 05:24 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I'll gladly change it to whatever you prefer. And thanks for understanding the reason.
Old Apr 30, 2013 | 09:25 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by abdodge1500
no more "NO BUS" or dash lights they are gone and gauges are working as they should, I checked fuse panel and popped hood and that guy put part of intake that says "dodge magnum" on backwards, put It back right way and no lights, also blew dust out of fuse panel
NO BUS indicates no communication between the PCM and other modules such as the cluster and key sensors.
it can be caused by unconnected ground wires, broken wires, unplugged sensors, bad sensors, loose or tarnished plugs to the cluster or PCM.
a common problem is the big white plug in the power dist. box beside the battery. the white one with the bolt in the middle. disconnect battery when messing with this. unbolt and connect/disconnect it several times and then rebolt it. the bolt will act like its stripped at the bottom. that's normal to prevent overtightening.
Old May 1, 2013 | 09:15 PM
abdodge1500
That would be nice, to change the name so others with this issue, could u change it to " truck will start but quickly dies without giving gas" and I figured out why I was having battery problems, the guy before me that the truck put diesel or bigger truck terminal connections and the wire wouldn't fit properly so I changed them and everything is great!
Old May 2, 2013 | 04:42 PM
zman17's Avatar
zman17
Done! And glad you got her fixed.
Old May 2, 2013 | 07:06 PM
abdodge1500
yes, I'm glad that I finally figured out that problem. I love my first truck
abdodge1500
and absolutely cant wait to drive it to school in august in my junior year.
