Odd Transmission Question
Old Apr 30, 2013 | 11:14 AM
Annihilator_X9's Avatar
Annihilator_X9
Default Odd Transmission Question
What parts of the trans are engaged in neutral?
Old Apr 30, 2013 | 11:17 AM
The pump is running, as is the torque converter, aside from that, anything else moving is just from fluid movement. (so, if you are stopped, in neutral, put the t-case in neutral, and then try and shift to 4 low, it WILL grind.)
Old Apr 30, 2013 | 11:23 AM
Annihilator_X9
That's what I thought. Perfect, thanks HeyYou!
