1998 dodge ram 5.2 dies when foot off is off gas
Old May 5, 2013 | 08:36 PM
taylorreis907's Avatar
taylorreis907
Default 1998 dodge ram 5.2 dies when foot off is off gas
I have a 1998 dodge ram with the 5.2. Recently had a clogged cat, did exhaust work to it, and then this issue started. The RPM's will either suck down really low when I take my foot off and come back up to idle speed, and sometimes the motor will simply stall. Replaced Idle air control and TPS already, before the cat clogged up it ran perfect. Help??
Old May 5, 2013 | 08:54 PM
BrandonBuc'em's Avatar
BrandonBuc'em
i went through something like this too when my battery died and i jumped it. before it died it would idle around 1200 rpm and now it idles pretty low at 400 to 600. it no longer stalls out. im not exactly sure what the issue is so im gonna stay tuned to this thread
Old May 5, 2013 | 08:56 PM
gdstock's Avatar
gdstock
Did you clean out the IAC port out good?
Did you disconnect battery when you changed out IAC and TPS?
Old May 5, 2013 | 09:16 PM
Ramzy's Avatar
Ramzy
One thing I have noticed over the years with my truck is if the battery is weak it will do this. However, for the OP, x2 on gdstock.
Old May 5, 2013 | 09:36 PM
taylorreis907
Battery and alternator are brand new, this ones got me stumped, haha
Old May 5, 2013 | 09:38 PM
taylorreis907
However, I did have to run it for a couple days with just headers imbetween the exhaust work i did.Really hoping my valves aren't gone through
Old May 6, 2013 | 11:04 AM
have you tried cleaning the Throttle body, and IAC well?
Old May 7, 2013 | 02:04 AM
taylorreis907
Yeah, removed throttle body, and cleaned thoroughly, then threw new iac in
Old May 7, 2013 | 08:52 AM
And that didn't solve it? If not, test TPS.
