Stearing problem with 2001 1500 slt 5.2
Old May 13, 2013 | 09:37 PM
merritta's Avatar
merritta
Default Stearing problem with 2001 1500 slt 5.2
Is thid truck know to have a power stearing problem. My truck is fairly stiff especially turning left.
Thanks
Merritt
Old May 14, 2013 | 12:44 AM
ryan0714's Avatar
ryan0714
only when going left?
you might try checkin the steering box, maybe someone made it to tight, there is a bolt on top with a nut on it, you undo the nut a little and then u can turn the bolt with a flathead, dont turn it much, just like 1/4 at a time, right makes it stiffer, left would loosen it some.
Old May 14, 2013 | 01:59 AM
Matt Nickerson's Avatar
Matt Nickerson
steEring*
I would be checking fluid level before anything else. Should be at the 'full cold' mark when cold...and full.
Old May 14, 2013 | 02:33 PM
merritta's Avatar
merritta
Thanks, I check the fluid level and its fine. I will check the steering box this weekend. It has 128,000 on it. Should I consider a flush?
Old May 14, 2013 | 04:27 PM
Can't hurt...
