PCM question
Old May 16, 2013 | 02:42 PM
ccd1977's Avatar
ccd1977
Default PCM question
ok. I found out I have the death flash. Can I use the PCM from a 1997 Dodge Ram 1500 for a cheap replacement until I can afford a tune?
Old May 16, 2013 | 02:48 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Nope.
Has to be flashed with the VIN and there were a bunch of sensor changes between 97 and 01.
Old May 16, 2013 | 02:50 PM
ccd1977's Avatar
ccd1977
ahh. ok. thanks.
Old May 16, 2013 | 05:11 PM
AtomicDog's Avatar
AtomicDog
The PCM is not required to have the VIN of the vehicle in it to run. The key is to match the part number on the PCM in your truck to the used PCM you plan to install on your truck. I purchased a used PCM off of eBay that matched my original PCM's part number, installed it onto my truck and everything worked just fine.. At some point, I plan to have the dealer flash my new-to-me PCM with the VIN, along with the factory tune (less the death flash).
