Vibration sometimes @ 40-45 mph
Old May 12, 2013 | 01:52 AM
00SilverRam's Avatar
00SilverRam
Default Vibration sometimes @ 40-45 mph
I get a vibration sometimes @ 40-45 mph. OD does not make a difference. I have researched the death wobble, but that sounds much more violent than what I'm experiencing. Replaced the tires as they were shot anyway and got an alignment. Still have the issue.
Any thoughts outside of death wobble?
Old May 12, 2013 | 09:02 AM
2 or 4 wheel drive?
Feel it more thru the seat, or the steering wheel?
Does your brake pedal pulsate when you step on it?
Old May 12, 2013 | 11:13 AM
00SilverRam
Thanks for the reply.
4wd.
Feel it in the seat.
No, the brakes don't pulsate.
Old May 12, 2013 | 11:26 AM
Check rear u-joints, inspect rear tires, might even rotate them, and see if the vibration moves.
Old May 12, 2013 | 02:41 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I have the same issue as well. Tires didn't help it, it's not a misfire.
I had done some googling and found posts on here, it's pretty common and not usually an issue.
You COULD have a u-joint going out, but I wouldn't really worry about it until it actually goes. I've been driving my rig this way for 3 years now with zero issue.
Old May 12, 2013 | 03:59 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1 on the rear joints. Could also be a bent or not balanced rear shaft. Had the same prob with my 98. The rear driveshaft was bent some and missing a balance weight.
Old May 15, 2013 | 10:39 PM
00SilverRam
Thanks for the replies guys. The u-joints seem to be fine and no weights are missing on the drive shaft. Hrmmm..... Perhaps kicking it will make it better!
Old May 16, 2013 | 12:01 AM
wheels1388's Avatar
wheels1388
I had the same issue for a while. Balanced the tires, seemed to help a little but not all the way. Come to find out one of my shocks was shot so got new ones and no issues after that.
Old May 16, 2013 | 10:36 PM
00SilverRam
Again, thanks for the replies guys. I'll check out the shocks as well this weekend.
