97 1500 5.2L - Coolant under valve covers, exhaust, not on dipstick
Hi all. My buddy has a 1997 Dodge Ram 1500 5.2 with about 240k miles. He drove around town the other day and the truck overheated and stalled. I came over and replaced the thermostat. We got it back home and noted that there was a small hole in the radiator. Fixed the leak and tested in the morning.
Filled the radiator, ran the engine until warm...no leaks. Drove about 5 miles down the road and noticed water vapor coming out the tailpipe. Truck stalled and we pulled off the air cleaner. We ran the motor again and noted the following:
I know it is possible that the throttle body and exhaust water vapor could be coming from the intake manifold PCV port. I originally thought the new-found water pressure on the system likely assisted in blowing a head gasket thereby allowing water under one valve cover and to a cylinder. Now that I see it in both, I'm not so sure.
Question 1: How is it possible for both heads to get so much coolant under each valve cover?
Question 2: Where is it likely coming from? What is leaking, transferring, etc?
We have a FelPro engine gasket kit with replacement gaskets for both heads, intake, TB, etc.
- Water was coming from both hoses out of the valve cover.
- Water vapor coming up from throttle body.
- Water vapor in exhaust.
- No water present on dipstick oil
