abs self test
Old May 17, 2013 | 08:36 PM
StephenDrouin's Avatar
StephenDrouin
Default abs self test
my 1999 dodge ram intermittently fails it's self test at start up and leaves the abs and brake lights...my speedo works with the lights on...it has a rear speed sensor but i was told if the speedo works the sensor is ok...any info would help...
Old May 17, 2013 | 09:07 PM
There is another sensor in the trans, might be that one as well... (but, I doubt it) Do the lights simply stay on after you start the truck, before you move?
Rear wheel, or four wheel ABS?
Old May 20, 2013 | 04:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The sensor on the rear end does not always screw with the speedo. If it's bad or on it's way out.
Old May 20, 2013 | 09:43 PM
StephenDrouin
thanks i may try replacing it..it's not too expensive....can the proportioning valve or abs block next to the master cause this?
