Cloyes double roller timing set 3028X question
Old May 24, 2013 | 10:18 AM
AtomicDog's Avatar
AtomicDog
Originally Posted by zman17
I forgot to mention that the 3072 cloyes(single roller) is listed for all years. Same set, LA or Magnum. Makes no sense to me.
+1 - makes absolutely no sense to me, however, I'm always open to learning something new - Chrysler small block has used the same chain design/setup for many, many years now... You can also retrofit a gear drive or a belt drive setup, if desired, so this issue is a real head-scratcher to me...
Old May 24, 2013 | 10:34 AM
ChillyPhil's Avatar
ChillyPhil
I plan on getting the Cloyes timing set too. For only around 43 bucks, it isn't a bad deal. Plus some other members encouraged me to get it when I do my tune up.
Old May 24, 2013 | 10:42 AM
merc225hp's Avatar
merc225hp
Or for a few dollars more.
Org Mopar Performance parts.
Timing chain tensioner part # P5007709 $31.95
Double Roller Chain and Sprocket Set part # P5249267 $62.50
Old May 24, 2013 | 10:54 AM
ChillyPhil's Avatar
ChillyPhil
So this would be better than the Rockauto deal?
http://www.summitracing.com/parts/DCC-5249267/
Old May 24, 2013 | 11:05 AM
AtomicDog's Avatar
AtomicDog
+1 on the timing chain tensioner P5007709 - even the double roller chains stretch a bit with time - the tensioner keeps valve timing rock solid for years - I have one in my 5.9 truck motor and love it..
Old May 24, 2013 | 02:34 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
+2 on the tensioner. I bought one and added it to my 5.9 that I am building right now too. Just takes some of the worry away.
Old May 25, 2013 | 08:07 AM
Spillage's Avatar
Spillage
I just looked through Larry Shepard's "How to Modify Your Mopar Magnum V8"... he is intimate with these engines and very good at noting the differences between A, LA and Magnum engines, and any variations between 5.2L and 5.9L versions.
When it comes to timing sets, the A engines silent chain used a nylon cam sprocket, but the LA and Magnums used all metal sets.
For increased HP applications it is recommended to use Mopar Performance or Cloyes double roller timing sets.
He mentions that the Magnums use a smaller key on the cam sprocket, and will not work with the A series engine, but there is no other mention of there being differences between engine series.
This would suggest that LA and Magnums should be the same.
Old May 27, 2013 | 06:13 AM
Jacksoncove's Avatar
Jacksoncove
Thankyou Spillage for doing the research I think your reply and Zmans reply has sold me on installing this
Old Jun 3, 2013 | 06:58 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Double roller installed today on the OP's truck, and it runs great.
Old Jun 3, 2013 | 07:11 PM
Arde's Avatar
Arde
Straight up? Or advanced? Just curious.
