Truck stalls
Old May 22, 2013 | 06:16 PM
TheBigRedTruck's Avatar
TheBigRedTruck
Default Truck stalls
As i was driving I noticed a slight hesitation while driving. I came to a stop sign and it stalled. I started it back up and it sounded like it had 4+ misfires. I have no check engine light. Where do I start? Got it home, but during the drive home it would go down to 200RPM and rev up without me giving gas.
Old May 22, 2013 | 07:00 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Try cleaning the IAC and throttle body. Disconnect negative battery cable first. https://dodgeforum.com/forum/dodge-r...n-the-iac.html
Old May 22, 2013 | 11:11 PM
ryan0714's Avatar
ryan0714
+1 on the idle air control on the back of the throttle body, clean the sensor and the canal it goes into.
Old May 23, 2013 | 01:00 AM
TheBigRedTruck
I hit the gas tank with a hammer and it drove great for a minute and died. Must be the fuel pump.
Old May 23, 2013 | 12:55 PM
zman17's Avatar
zman17
Get a cheap pressure tester and check first.
Old May 23, 2013 | 10:10 PM
TheBigRedTruck
well i switched the relay and still cant hear the fuel pump when i turn the key to the RUN position. i tried starting it but it couldnt. hit the tank and it started.
