97 ram 1500 leaking coolant like crazy. HELP
Old May 24, 2013 | 06:05 PM
BrandonBuc'em's Avatar
BrandonBuc'em
Default 97 ram 1500 leaking coolant like crazy. HELP
ok so i was driving today, i turned the heat on very low, i started to smell coolant so i shut it off. when my passenger got in the truck she stated that something is leaking down from center of the console. she touched it, it was coolant. i pulled over, huge puddle of coolant leaking on passenger side. i instantly thought the heater core ****in bust in half for this much leaking. upon request i can post pictures but does anybody know based off these conditions noted its deffintly the heater core and how hard it is to replace? please help!
Old May 24, 2013 | 06:08 PM
chromed95's Avatar
chromed95
Yup, sounds like the heater core. You had the huge puddle inside the cab or was it outside? Just a matter of taking the dash out to get to it. Haven't done it myself but its probably a couple hour job at least.
Old May 24, 2013 | 06:12 PM
BrandonBuc'em
both the interior and the outside. more so inside then the outside. prior to todays heater core busting its been leaking coolant. anything that could have lead up to this? what causes the core to go?
Old May 24, 2013 | 06:22 PM
chromed95's Avatar
chromed95
Not exactly sure what leads up to it maybe just old and tired or they plug up and start leaking, but it seems like a common dodge thing just like the plenums. Mine went out about 6 or 7 years ago and I just took it to a shop for replacement. Wish I would of did it myself for cost reasons.
Old May 25, 2013 | 01:38 PM
BrandonBuc'em
i just bypassed the heater core. cut the inlet and outlet hoses and plugged the ends that go into the core at the firewall. and clamped the two hoses together. i dont need heat right now anyway.
