U Joint Help Please!
Old May 30, 2013 | 04:55 PM
DodgeRam10's Avatar
DodgeRam10
Originally Posted by zman17
Well you didn't answer the question about when the wheel is turning? What wheel? The steering wheel?
Sorry I overlooked that, any time the wheels were spinning. If i drive forward going 1 mph or 50 it makes the noise. I just jacked up the rear tires,put it in nuetral and turned the rear wheels and I couldnt hear anything. If I turn one wheel the opposite wheel turned with it in same direction so I assume I have lsd. Any way couldnt hear the scraping noise at all. I did however hear a small whinning noise either at the front of t case or rear of tranny along with either gears engaging or something. My rear tcase seal was bad and I changed with the u joints so Im gonna top off the fluid but even then it wasnt the scraping noise i heard.
Old May 30, 2013 | 05:19 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Time to jack the front up. I'm assuming you have a 4x4 because you said TC earlier. Please add that info to your sig and profile.
Old May 30, 2013 | 05:39 PM
DodgeRam10's Avatar
DodgeRam10
jacked up the front, didnt hear anything other than the front brake rotors. Took it for a drive and didnt hear the scrap ing noise. Maybe it was a rock or something stuck somewhere?? Ill drive it some more tomorrow and let you know if I hear it again
