Rear Differential Question
Old Jun 1, 2013 | 02:25 PM
abdodge1500's Avatar
abdodge1500
Default Rear Differential Question
I have 2000 dodge ram 1500 sport 5.9 2wd and I want to change my rear differential fluid because I don't think it was replaced by the previous owner, I have a Chrysler 9.25 anti spin rear axle 3.55 gear ratio (this is coming from a build sheet dodge sent me). well I called a local fluid change shop here and they said it takes synthetic so it will cost $99 to get it replaced. is this a good price? what gear oil does the truck take? I read on here synthetic is for heavy duty and this truck doesn't tow or haul anymore, its just being used as a daily driver. I'd be open to doing this myself if there is not that much to it. also, how much would a good price be for it to be replaced by a shop?
Old Jun 1, 2013 | 03:00 PM
dhvaughan's Avatar
dhvaughan
this is a perfect job for you to do yourself.
http://www.pavementsucks.com/tech-article-4.html
you can get your gear oil from walmart in a gallon jug for about $14. either 85w90 or 75w140, it doesn't matter which one.sqirt
it'll take about 2-1/2 quarts.
you'll need to devise a way to pour the oil in. like pour it in a used quart oil container, then squirt it in.
don't waste money on the little pumps. it'll break.
http://www.walmart.com/ip/Super-Tech...allon/16795066
you also need the little 4-6 oz bottle of friction modifer. walmart might have it, or parts store if they don't
http://www.oreillyauto.com/site/c/de...il+-+additives
Old Jun 1, 2013 | 05:15 PM
abdodge1500
thanks for everything and what socket should be used for taking the bolts off? 5/8?
Old Jun 1, 2013 | 05:19 PM
dhvaughan's Avatar
dhvaughan
no, they're little. more like 7/16 or 12mm.
use a stiff putty knife to separate the cover from the diff. don't bend the cover and don't scar the diff face.
Old Jun 1, 2013 | 05:38 PM
abdodge1500
okay thanks, should I buy a new gasket or use RTV sealant?
Old Jun 1, 2013 | 05:44 PM
stewie01's Avatar
stewie01
Bead of RTV should do.
Old Jun 1, 2013 | 06:09 PM
abdodge1500
okay great well I priced how much everything would cost. DIY= about $50 that definitely beats the $99 Valvoline oil change would charge me lol
Old Jun 1, 2013 | 06:21 PM
stewie01's Avatar
stewie01
Here's a better looking (to me) DIY of the job, https://dodgeforum.com/forum/2nd-gen...cover-off.html
Old Jun 1, 2013 | 07:17 PM
dhvaughan's Avatar
dhvaughan
$14 for walmart gear lube.
$8 for friction modifier.
$5 for rtv
$4 for a can of brake cleaner to clean the bottom of the diff.
1/2 wrench, putty knife, paper towels, wire brush.
i only come up with $31.
clean the magnet in the bottom. don't be surprised if you find broken fragments of clutch retaining clips. its common in these lsd's
Old Jun 1, 2013 | 10:25 PM
abdodge1500
I'm getting a oil drop pan for this and future fluid changes. and one final question, as far as tightening the bolts back up. how tight should I tighten them? I don't have a torque wrench. I know not to tighten all the way that I cant turn any further.
