95 Ram rebuild
Old Jul 5, 2013 | 06:35 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Unplug the sensor, should be the 2 wire. Although your pic looks like 1 wire. Go to Rock Auto and look at the pics and order the correct one.
Old Jul 5, 2013 | 06:45 PM
Rescue35's Avatar
Rescue35
Thanks Zman, There is only one wire going to this sensor. (assuming temp...I'll have to break out the manually).
Old Jul 5, 2013 | 06:54 PM
zman17's Avatar
zman17
I'm going with a TS271 Standard Motor Products sensor.
Old Jul 5, 2013 | 09:44 PM
Single wire is the sensor for the gauge. (temp)
Old Jul 15, 2013 | 02:04 PM
Rescue35's Avatar
Rescue35
It is running a lot better now that the plenum is not leaking. No noticeable oil consumption although I haven't driven it much. I have a coolant leak some wear around the water pump to chase down. Still have to get the correct coolant sensor as oreilys can't get it right. I have the correct one coming from rockauto.
I want to get my "Overhead console W/ Temp and Compass" working. I didn't even notice it on the mirror until I received the build sheet. Also I do not get a 4X4 light when engaging the transfercase. I can not wait to remove that entire vacuum system.
The build sheet is below just for fun.
Thank you for contacting the Dodge Customer Assistance Center.
We are pleased to provide vehicle build information per your request.
According to our records, your vehicle was equipped from the factory
with the following:
*P1 Premium Cloth 40/20/40 Bench Seat
ADAP Light Group
AJKP Convenience Group
AJPP Power Convenience Group
APAS Monotone Paint
ASPP SLT Decor Group
AWK Travel Convenience Group
BARP 90 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKAS 11x2 Rear Drum Brakes
CBEP 40/20/40 Split Bench Seat
CGTS Driver Air Bag Only
CHEP Deluxe Headliner
CKEP Front Seat Area Carpet
CLAP Front Floor Mats
CSPS Passenger Assist Handle
CSRP Passenger Assist Handles
CUNP Overhead Console w/Temp & Compass
DGB All 4-Speed Automatic Transmissions
DGRS 4-Spd. Automatic 46RH Transmission
DHAS Lock-Up Torque Converter
DHKS Shift-on-the-Fly,231HD Transfer Case
DJCS 195MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
EAAC All Engines
ELF 5.2L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GFD Rear Sliding Window
GNKP Rear View Auto Dim Mirror
GNMP Passenger Side Sun Visor w/Mirror
GPPP Power 6 x 9 Bright Mirrors
GVBC All Vehicles W/Power Mirrors
HAAP Air Conditioning
HGAP Hood Insulation
HGBS Dash Liner Insulation
JAYP Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBP Dual Note Electric Horns
JJJP 12V Auxiliary Power Outlet
JPAP Power Windows
JPBP Power Locks
JPS Power 6-Way Driver Seat
JRDP Power Driver Seat
KA8A STRIPE/BADGE/MOLDING/DELETE
K17P Bodyside Molding
LAAP Ignition Time Delay Lamp
LAGP Warning Chime
LBAP Map/Courtesy Lamp
LBCP Glove Box Lamp
LDAP Underhood Lamp
LMAS Halogen Headlamps
LPEP Cargo Lamp
MBFP Bright Rear Bumper
MCTP Bright Front Bumper
MFDS Bright Grille
MHAS Black Windshield Moldings
MPBP Black Tailgate Applique
MPFP Tailgate Top Protection Molding
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCP Front Bumper Sight Shields
NAAS Federal Emissions
NBKS EVAP Control System
NFWS 26 Gallon Fuel Tank
NHMP Speed Control
PX8 Black Clear Coat
QX8S Black Clear Coat
RAAC All Radio Equipped Vehicles
RAY AM/FM Cassette Radio w/Equalizer
RCEP Infinity Speakers
RDDP Fixed Long Mast Antenna
SBAS Variable Assist Power Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMP Tire Carrier Winch
TXD LT265/75R16C OWL All Terrain Tires
TZAP Goodyear Brand Tires
WDBP 16X7.0 Chrome Wheels
WLBP Steel Spare Wheel
WLYC All Steel Wheels
WMJP Center Hub
XBSS Pickup Box
XCMS Vendor Painted Cargo Box
YAAS Build To U.S. Mkt. Specifications
Thanks again for your email.
Sincerely,
Josh
Customer Service Representative
Old Jul 15, 2013 | 02:06 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
The compass shouldn't be in the mirror, it should be in that little console where the map lights are located.
Old Jul 31, 2013 | 03:53 PM
Rescue35's Avatar
Rescue35
No such console in this truck. Oh well. Quick dumb question, will mirrors from a 99+ fit on a 95? I might even try to get the power versions to work.
I did get the O2, coolant temp, and oil pressure sensors replaced. No more red lights on the dash and it runs like a champ.
I have the new condenser for the AC installed. Just need to charge it up and find out what is preventing the compressor from coming on.. I also installed the B&M Oil Cooler http://www.summitracing.com/parts/bmm-70264 and the Perma-Cool remote http://www.summitracing.com/parts/prm-10678 filter for the tranny.
Old Jul 31, 2013 | 03:58 PM
dodge dude94
It ought to have one regardless.
Can you take a picture of the headliner?
99+ mirrors will physically fit the door, as far as the electrical, I have no idea. I'd imagine SOMETHING changed along the way...
Old Jul 31, 2013 | 04:29 PM
Rescue35's Avatar
Rescue35
Here you go.
Old Jul 31, 2013 | 04:32 PM
dodge dude94
That's the console I'm talking about. lol
Dodge never had a compass/temperature gauge in the rear view mirror, it was in where compartment that you have right there.
I can post a picture of mine if necessary. But that's what I was speaking of.
