And there any way I can get to the blend door without yanking the dash out?
It may not necessarily be the line going to it, but yes check it. This one is located on the firewall, passenger side. You'll see it go in towards the hvac unit as well as other lines going elsewhere on your rig. Such as to the intake manifold, cruise control, etc. Also check down underneath and look at the 2 lines going from the front axle CAD to the transfer case.
You don't have to yank the dash out....yet.
Search on Youtube my username, and find the video I have for heater treater.
Looked at vacuum lines, they all look good. I don't have wild vents, as my air isn't going toward the defrosters. It just seems like something is in its way. Recirc door is working fine. Blender for the heat is working fine.
