Belt assembly.
Old 06-17-2013, 10:07 PM
Matt_yarek's Avatar
Matt_yarek
Matt_yarek is offline
Default Belt assembly.
hey everyone have a squeaky belt anyone know how to fix this>>? 2001 ram 1500 v8
Old 06-17-2013, 10:29 PM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
Pull off the belt and inspect it. No bad glazing on either side or cracks, it's not the belt. Then spin all your pulleys and see which one (if any) are an issue.
Old 06-17-2013, 11:59 PM
Matt Nickerson's Avatar
Matt Nickerson
Matt Nickerson is offline
Does the belt feel loose? There should be no more than a 1/2" of deflection per foot of the belt. Make sure the tensioner isn't binding. If you recently spilled antifreeze, ps fluid, or anything else, it can cause a squeak. Just pull off the belt, spin all pulleys (minus the crank pulley) and listen for any noise or binding. If everything seems in check, buy a different brand belt. The two brands that seem to work for most are dayco and gatorback.
Old 06-18-2013, 12:11 AM
dodge dude94
+1 on Dayco.
Old 06-18-2013, 12:16 AM
Paul DeHayes's Avatar
Paul DeHayes
Paul DeHayes is offline
+1 on Dayco.
^^^^This
W-rib Dayco's are great belts, had one on my Grand Prix, been on there for a few years and has been parked a year, looks and feels like new still.....
Old 06-18-2013, 12:49 AM
Matt Nickerson
For whatever the dayco belt will squeak right out of the box for my truck.. And the gatorback is fine. And I've heard others say the same, as well as the opposite.
Now I just keep the dayco as a spare. If I'm bored one day, I'll swap the dayco in and see if it still acts up.
Old 06-18-2013, 12:50 AM
dodge dude94
My Dayco has been fine ever since I put it on 2 years ago.
Old 06-18-2013, 06:59 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
possible causes of squeak are:
bad belt
bad idler pulley bearing
bad tensioner assembly or pulley bearing
bad water pump
ps pulley not pressed on deep enough
bad alternator bearing.
bad AC compressor clutch or bearing.
Old 06-18-2013, 12:10 PM
chromed95's Avatar
chromed95
chromed95 is offline
I use a napa belt, no problems, squeaks or anything...yet. Kind of second guessing it now with all this dayco talk.
Old 06-18-2013, 10:00 PM
Matt_yarek's Avatar
Matt_yarek
anyone order right from mopar?
Quick Reply: Belt assembly.
