help on fuel pump
Old Jun 19, 2013 | 05:02 PM
foxdeane's Avatar
foxdeane
Default help on fuel pump
1996 ram 1500 5.9L-26gal tank==fuel pump quit-purchased new online @buyautoparts.com-dropped into tank and realized wiring wrong-pump harness has 4 leads and truck harness has 6 leads--and none of the colors on sheet listing different wiring combinations match actual colors on truck harness--am lost as to what to connect to what--fuses and relays also replaced--could use some help!!
Old Jun 19, 2013 | 05:33 PM
Welcome to DF! I will move this to the appropriate section.
Old Jun 19, 2013 | 05:44 PM
stewie01's Avatar
stewie01
Any chance you ordered the wrong year part or they sent you the wrong part?
Might could take the new one to a local auto parts store and ask to compare it to one of their pumps for your truck, see if the wiring is similar or way off...
Old Jun 19, 2013 | 09:13 PM
guzman's Avatar
guzman
If I remember correctly my replacement pump on my 96 had a pigtail adapter on it, sure you did not have one in the box or did it show one on the intruction sheet?
Old Jun 19, 2013 | 09:36 PM
merc225hp's Avatar
merc225hp
^^^ That would be right, from my understanding its a 96 only thing. The new pump should have come with one of these.
Old Jun 20, 2013 | 04:00 PM
foxdeane's Avatar
foxdeane
thanks to all who responded--vendor is sending pigtail adapter o'nite--was not included with pump--will let you know how it turns out....
