Transmission Slipping in Overdrive
Old Jul 9, 2013 | 07:28 AM
renardk764's Avatar
renardk764
Default Transmission Slipping in Overdrive
My transmission is slipping in overdrive when running the A/C on hot days. The truck has the factory external transmission fluid cooler sandwiched between the radiator and the A/C condenser. I'm wondering if the heat load from the condenser is causing the slipping. The transmission has unknown milage due to being a used transmission installed by the PO prior to me getting the truck. Should I try remounting the cooler, flush it, or start planning for a transmission rebuild? I changed the fluids and filter yesterday. 2001 1500 with 5.2 and 46RE
Thanks!
Old Jul 9, 2013 | 11:28 AM
gertie240's Avatar
gertie240
Did you get a chance to clean the gov. and pressure sol. when you changed the oil? I wish I had a torq-flight
Old Jul 9, 2013 | 12:48 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Thanks!
You could try removing the check valve and getting a bigger aftermarket tranny cooler(do a search here on DF, lots of info on that) Also adding a tranny temp gauge will help a lot. And btw, you say slipping ? RPM surging but truck still moves? What happens when OD drive is off? Any CEL ?
Old Jul 9, 2013 | 05:55 PM
jconlin's Avatar
jconlin
I'm not trying to thread jack but I have a question, my truck does that, at highway speeds (55mph) when the engine is turning about 1500 rpms it will surge to about 1700 and the right back down, I never thought a whole lot about it but is it actually slipping?
Old Jul 9, 2013 | 05:58 PM
gertie240's Avatar
gertie240
zman do you know what size the AN fittings are?
Old Jul 9, 2013 | 06:07 PM
renardk764's Avatar
renardk764
I deleted the check valve a few months ago. Didn't clean the solenoids. What happens is the truck usually runs about 1900 Rpms at 70. With A/C on and sitting still long enough for the temp to start creeping up the Rpms move to 2200-2400 rpm. Once I get a nice long straight away with no traffic and consistent airflow at 70 the Rpms slowly move back to normal operating range. The factory cooler is pretty large. Probably 12x16.
Old Jul 9, 2013 | 06:10 PM
renardk764's Avatar
renardk764
I replaced the fan clutch and burped the cooling system. Also changed the water pump within the last few months.
Old Jul 9, 2013 | 06:12 PM
renardk764's Avatar
renardk764
BTW, I did add a drain plug to the transmission pan when I did the filter/fluid change. :-)
Old Jul 9, 2013 | 06:23 PM
gertie240's Avatar
gertie240
will these plus some high pressure hose work?
http://www.makcotransmissionparts.co...0001/13030.jpg
Old Jul 9, 2013 | 06:52 PM
renardk764's Avatar
renardk764
No cel light. No slipping when od is off.
