How to tell an A/C compressor is bad?
Old Jul 11, 2013 | 07:59 AM
Mopar00's Avatar
Mopar00
Default How to tell an A/C compressor is bad?
I'm trying to figure out how to tell of the compressor is bad. When I had the truck running I would here a clicking noise so I went and looked and the compressor would click on and then click off. What does that mean?
Old Jul 11, 2013 | 08:02 AM
Compressor cycling on and off usually means it is low on refrigerant. Post some details about the vehicle so we can get you to the correct technical section for help. (model, year, engine size, transmission, mileage, etc).
Old Jul 11, 2013 | 08:04 AM
Mopar00's Avatar
Mopar00
2000 dodge ram 1500 4x4 5.9L automatic and around 97,000 miles. Thank u for ur help
Old Jul 11, 2013 | 08:12 AM
Get yourself a can of refrigerant and a refill kit (walmart sells them), add a can and see if that helps.
Old Jul 11, 2013 | 08:36 AM
Mopar00's Avatar
Mopar00
Ok thanks
Old Jul 11, 2013 | 09:28 AM
And be sure to check out the 2nd Gen Ram section for more info on your truck.
Old Jul 11, 2013 | 08:43 PM
dhvaughan's Avatar
dhvaughan
get the refill kit that includes the simple little gauge on the fill line. it allows you to check your low side pressure to know if you are low or high or on-target. it has a color coded gauge for low, correct, and high. keep the gauge hose after you are done - and you can check pressures anytime you need, and if you ever need another kit you can get the one w/o the gauge and save a dollar or two.
