1997 dodge ram trans leak
I have a 1997 dodge ram slt 1500 pick-up. there is transmission fluid leaking between the transmission and the transfer case. is there a seal some where or is it just a gasket between them? transfer case is a 231D the only thing is that when you google it keeps referring that is goes to a Jeep not a dodge ram truck
Two seals actually. One for the trans, one for the t-case. They both use ATF +4. Need to drop the t-case. Replacing both seals makes sure you don't have to go in there again for a while.
