Temp Gauge not working
Old Jul 14, 2013 | 05:45 PM
onefast79camaro's Avatar
onefast79camaro
Default Temp Gauge not working
I have a 1996 Dodge Ram 2500 V10. Recently the temp gauge stopped working. It doesn't even move. The connector on top of the sensor felt like it was ready to break so I replaced the sensor. Still didn't work. So I checked the sender, and it felt like it was ready to break as well so I replaced it. Now when the key is on the neddle moves up a little, but it still doesn't read any temperature. Any ideas?
Old Jul 14, 2013 | 07:53 PM
stewie01's Avatar
stewie01
Thermostat?
Old Jul 15, 2013 | 07:46 AM
Should be a 2 wire sensor on the V-10. Should see 12 volts on the Violet/Yellow wire with key on. White wire goes to ground. Make sure both wires are doing their jobs.
Old Jul 16, 2013 | 09:34 AM
onefast79camaro
Originally Posted by stewie01
Thermostat?
I am DEFINATELY not dismissing any ideas, but I replaced the thermostat in Janurary. Since then I've put 550 miles on the truck. Is there an easy way to test this?
Old Jul 16, 2013 | 09:35 AM
onefast79camaro
I will check this out tonight. Thanks!
