Big time A/C leak
Old Jul 15, 2013 | 10:18 PM
ramitt360's Avatar
ramitt360
Default Big time A/C leak
It's leaked out slowly since i got the truck about 5 years ago. The other day there was not enough to kick the compressor on, so i added of that dye and was going to attempt to find the leak. After adding that can i sat in the cab where the air smelt like the can i just added. I could hear liquid/oil, leaking from in the dash so i take it my evap core is toast..
My question is this, is this a project I should tackle or take it somewhere? I did not see a diy here on this. There is still pressure in the lines but not enough to run the compressor. About the only thing I can't do is pump the remaining freon and what not out of the system to put a new core in.
OR, is this a good excuse to get a new ram?
Old Jul 15, 2013 | 10:42 PM
Take it somewhere and have it evacuated.
Look for the Heater Core DIY. Change that while you are in there. Read the procedure a few times, also check the service manual available for download in the faq section. Decide from there if you want to try and tackle this job.
Old Jul 15, 2013 | 10:45 PM
ramitt360's Avatar
ramitt360
Thanks
Old Jul 15, 2013 | 10:48 PM
If you decide to do this, take LOTS of pics.
Old Jul 15, 2013 | 10:52 PM
ramitt360's Avatar
ramitt360
Sure, however there are video's on youtube of a guy changing out his evap.
or
