Dodge Ram going through blower motor relays.
Old Jul 24, 2013 | 06:54 PM
TDPalmer's Avatar
TDPalmer
Default Dodge Ram going through blower motor relays.
About every month or so my Dodge's blower motor will stop working, and I can fix it by replacing the relay. It seems like after a while the relay gets weak and doesn't want to pull the contact closed. I can open the plastic cap on the relay and push the contact closed and the blower motor will work fine. The relay always goes bad while driving it, and when I go to replace it it's always burning hot. I've tried to trace a short on the wiring and in my blower motor with no luck. I've also tried different part's stores but I always get stuck with Borg Warner relays. No fuses are blown either when I have to replace the relay.
What could be causing my Dodge to go through so many relays?
Old Jul 24, 2013 | 06:55 PM
Check grounds.
Old Jul 24, 2013 | 08:19 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Maybe the blower resistor as well?
Old Jul 25, 2013 | 07:07 AM
Jacksoncove's Avatar
Jacksoncove
Good chance its the resistor its probably burnt and falling apart
