4x4 light comes on, X-Case Grinding
Old Jul 25, 2013 | 11:55 PM
possible neon owner's Avatar
possible neon owner
Default 4x4 light comes on, X-Case Grinding
99 ram 1500 auto trans 5.9 mag.
-Transfer case makes grinding noises when trying to move in 4x4 low or high. oil is good. linkage is good and adjusted. how to i remove the case? does anybody know of a thread with a step by step on removing it? or does anybody have any ideas on how to repair it. thanks!
Old Jul 26, 2013 | 12:49 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Have you tried putting the transmission into neutral before shifting? You didn't mention that aspect...
Old Jul 26, 2013 | 01:13 AM
possible neon owner
yes ive tried that. it just grinds when i try moving with it engaged, same story on snow, sand and mud.
Old Jul 26, 2013 | 01:17 AM
possible neon owner
i was able to get it engaged with the truck on jack stands once, the second i let it down and tried moving it popped right out. the light comes on when its shifted, but the front axle will not engage
Old Jul 26, 2013 | 07:10 AM
dhvaughan's Avatar
dhvaughan
i have a thread on a swap, and sheriff has a better one.
make sure you know the difference in the noises that come from the T-case, Cad, 4wd light, and vacuum lines.
a lot of tcase problems are just vacuum leaks.
Sheriff
https://dodgeforum.com/forum/2nd-gen...placement.html
Mine
https://dodgeforum.com/forum/2nd-gen...31-np231d.html
Old Jul 26, 2013 | 08:22 AM
nighthawk10mm's Avatar
nighthawk10mm
It sounds like a vacuum leak to me. I had one on my old GMC the way I delt with it was put the truck in reverse then shift the TCase. It never popped out that way on me. I did this until I was able to find the leak and fix it.
Old Jul 26, 2013 | 12:13 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1... could be a simple fix . At least give it shot before removing TC for nothing. http://www.dodgeram.org/tech/repair/..._engagment.htm
Old Jul 27, 2013 | 01:34 PM
ryan0714's Avatar
ryan0714
if you would rather do away with the vacuum like i did, just flip the fork for the CAD. so it will be ready to go all the time no matter what. ur front driveshaft and axles will all turn when doin this because of the tires turnin them, but they wont actually have power or pull until u engage the tcase. but it just eliminates the vacuum system.
Old Jul 27, 2013 | 03:18 PM
Cheap alternative to buying a posi-lok.
Old Jul 27, 2013 | 07:39 PM
dhvaughan's Avatar
dhvaughan
posilok lets you have 2wd LOW, which is really nice.
