Can fog lights be rewired to run on headlight relay?
My fog lights will not for for ****. I tested the relay and it is good. Using a multi-meter, I am not getting any power to the fog relay. I do get power from my headlight relay. I believe my switch on the dash is broke. (yes the bulbs are new)
Can I have a jump wire from my headlight relay to my fog light relay? Or what should I do?
Just replace the switch, why mess around with rewiring for no reason.
Welcome to DF
Please take the time to fill out all your trucks info, add it to your sig just go into your user cp and fill out the info.
Welcome to DF
Well I have no light coming on or anything. Is it just the switch or should I check any where like the wiring or ground wire by the fog light? Would this matter sense I'm not getting the switch to light up?
Trending Topics
Stupid thing is $75, but it was a very easy change (only complication is you need security torx (the star torx with a hole in the middle)).
I tried the headlight, foglight switch first and the new one made no difference. O'Reilly's took back the new one I had bought because I was buying the multi-function instead.
