Exchange engine mounts on a RAM 2500 V10 2001
Old Jul 30, 2013 | 02:35 PM
regnichlas's Avatar
regnichlas
Default Exchange engine mounts on a RAM 2500 V10 2001
Hello,
I´m writing from Austria and you guys are my "last" hope.
I tried to change my worn out engine mounts (front and rear) on my dodge ram 2500 V10 2001.
I´ve got the haynes manual and the dodge manual (pdf), but these both things are not really usefull for my "project" to change the engine mounts.
I´m able to lose all nuts and bolts, but I´m not be able to remove the front mounts from the vehicle.
I did the job, like it is describe in the manuals, but it won´t work.
Is there a special trick, or something else to finish this job?
I hope someone from you could help me and let me know the "secret procedure" to change the engine mounts.
Thanks for your efforts,
Peter
Old Jul 30, 2013 | 02:46 PM
Moving this to the correct forum.
Which side of the mount are you trying to change? Engine, or frame?
Old Jul 31, 2013 | 08:21 AM
regnichlas's Avatar
regnichlas
I tried to remove the engine mounts.
I´ve liftet the engine with a car-jack to take the weight off the engine mounts.
Then I removed all the bolts (3 x engine, 1 x frame), but i couldn´t pull the mounts through the gap between the engine and the frame.
Old Jul 31, 2013 | 08:31 AM
Can you lift the engine any higher? May try and do one side at a time. I know on my V-8, getting the mounts out was fun, but not too much of an exercise.
Old Jul 31, 2013 | 11:29 AM
regnichlas's Avatar
regnichlas
I´ll try to lift the engine a bit higher with my hoist, but therefore I´ve to remove the cowl, because the hoist is mounted on hook in the concrete ceiling in my garage.
I want to avoid this procedure, but it seems that´s the only way out to remove those engine mounts.
But nevertheless, thanks for your efforts HeyYou !
Old Jul 31, 2013 | 01:28 PM
merc225hp's Avatar
merc225hp
I have no experience doing this on a V10 but I have done this many a time on the 5.9. On the pass side, if you have one there is a trany to engine brace remove it, that will give you some extra wiggle room. I removed both mounts from the bottom and installed from the top. Soapy water for the install will help as well. I had the motor lifted to the point the fan was just touching the fan shroud. For lifting the motor I used a bottle jack and some wood between the diff and the oil pan, support the diff from underneath as well, not to sure if this would be wise on a V10 though just a bit heavier than the V8.
Old Jul 31, 2013 | 02:48 PM
clipper77's Avatar
clipper77
According to the service manual (year 1996), group 9-133, raising the engine and possibly disconnecting the transmission to allow for more wiggle room may be necessary to gain enough clearance to remove the motor mounts.
