3/4 ton coil on 1/2 ton with spacer?
Old Aug 10, 2013 | 03:00 AM
daneb84's Avatar
daneb84
Default 3/4 ton coil on 1/2 ton with spacer?
I have a 97 Dodge Ram. Has 3 inch spacer on front and add a leaf and blocks on rear. Rear sits about 2 inches higher than front so i was thinking about adding a set of cummins coil spring to get the 2 - 3 inches i need to level it out however i have read that over 3 inches you need to mess with the steering. So the question stands do i need to mess with the steering and if so what are my options? Thank You.
Old Aug 10, 2013 | 03:27 AM
merc225hp's Avatar
merc225hp
You would need longer upper and lower control arms, drop pitman arm, some flavor of track bar bracket or an adjustable one and other parts.
