headlight rouble
Old Aug 10, 2013 | 10:07 PM
timhortons_junkie's Avatar
timhortons_junkie
Default headlight rouble
I have a 1997 dodge ram 4-4 king cab 1500 mag. I start my truck put the lights on, they are on high beam, I dim the lights to low beam, high beam is still on at the same time. shut the truck off take key out of ignition my lights are still staying on would be thankful for any advise to this matter.
Old Aug 12, 2013 | 12:54 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. I will move your post to the correct section.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Aug 12, 2013 | 08:44 AM
Multifunction switch (headlight dimmer, turn signal switch) is stuck.
Old Aug 12, 2013 | 10:59 AM
gertie240's Avatar
gertie240
also pull the headlight relay and ohm it out.
Old Aug 12, 2013 | 05:28 PM
dhvaughan's Avatar
dhvaughan
no relay for headlights...
advance has a multifunction switch with lifetime warranty. if you use the discount code ES123 or similar you can get it for 30-40. you'll need the security torx (hollow tip) to remove it. you can get the set for about 10.
