5.9l gas no power
Old Aug 12, 2013 | 11:57 PM
pickupgear's Avatar
pickupgear
Default 5.9l gas no power
have a 98 dodge 1500 4x4 with 5.9. changed spark plugs, wires, rotor, cap, tans cycloid's. since problem, prior owner fixed ac and fuel pump. when I get on it I have no power like going up a hill it down shifts and loose speed I need help.... I tested the cat converter, loud yet no change what else... thanks
pickupgear's Avatar
pickupgear
thanks for the help ... I will try it and let you know or plst what I find out asap
Old Aug 15, 2013 | 07:50 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
You'd get more help if you posted in the right section. I will move you there now.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Aug 15, 2013 | 07:52 PM
stewie01's Avatar
stewie01
You should read the Plenum Thread at the top of the 2nd Gen Tech section, could be part of the problem.
Old Aug 16, 2013 | 12:40 AM
nighthawk10mm's Avatar
nighthawk10mm
+1 with Stewie. Also if you are running 35" tires or bigger with stock gears that will suck your power away like nobody business.
