2000 360 magnum build help
Old Aug 14, 2013 | 10:21 PM
BryanCampbell's Avatar
BryanCampbell
Default 2000 360 magnum build help
OK here what im looking to build a 360 magnum with as close as possible to 500 bhp as i can get without nos. im ok with 400 to 450 and adding nos for the rest. im going to use a Comp Cams 20-746-9 Computer Controlled Hydraulic Roller Tappet Camshaft RPM Range: 1200-5400 Lift: .506"/.506" Advertised Duration: 265°/273° Lobe Separation Angle: 114° what type of pistons should i use and should i change out my rollers and lifts if so what ones would ya'll suggest. this is going to be a street/strip truck with a little show added lol thanks for your input if i get hits on here ill even post picks of the before and after. so lets light this thread up please.
Old Aug 14, 2013 | 11:50 PM
First, let's move this to the correct forum.
Old Aug 15, 2013 | 12:28 AM
ryan0714's Avatar
ryan0714
sounds like u need to talk to IndyRam
Old Aug 15, 2013 | 08:23 AM
redneck_ram's Avatar
redneck_ram
im right around 400 bhp with my setup. i used the stock bottom end.
