Alt is not charging NEED HELP PLEASE
need help my 1995 dodge ram 1500 5.9 is giving me problem, i have a new alt, computer, harmonic balancer. my alt is not charging. when i start truck the battery's dies. please help
Welcome to DF.
How old and what shape is the battery in? Have you tested it?
Will move you to the correct section for better help.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
yes, voltage regulator is in the pcm.
start by testing the battery using multimeter with engine not running. normal is about 12 volts.
with engine running and alternator turning, probe the large wire, verify about 14 volts.
next probe the battery again, hoping for the same 14 volts.
what are your readings?
i found an artical on puting the old style reg on one like yours. ill try to hunt it down. be back soon. try this.
https://dodgeforum.com/forum/2nd-gen...onversion.html.
