Alt is not charging NEED HELP PLEASE
Old Aug 15, 2013 | 08:51 PM
terrywest551's Avatar
terrywest551
which when its starts up the alt should be charging the battery Right?
Old Aug 15, 2013 | 10:50 PM
charge the battery fully. Start truck, check voltages. Report back.
How long does the truck have to sit before the battery dies?
Old Aug 16, 2013 | 12:50 AM
ReadRam's Avatar
ReadRam
Right. Does gauge show charging or discharging? If you leave it battery cables on for a bit does it keep running. If i was going to guess I'd say battery is shot and wont take a charge. It is hard on alternators using them as battery chargers. Did you get 12 volts across battery terminals with truck shut off?
Old Aug 16, 2013 | 07:25 AM
terrywest551
yes the battery is doing its part i charge the battery full charge but it wont keep a charge
Old Aug 16, 2013 | 09:06 PM
ReadRam's Avatar
ReadRam
Take it back. If it's new there should be a warranty. I've had batteries that passed the load test, but every morning it would dead. Autozone gave me a new one and it worked fine. And I have got bad ones from Sears that were shot in a month. It happens.
Old Aug 16, 2013 | 10:07 PM
Question becomes, was it doing this with the old battery as well?
