Spark plug question.
Old Aug 18, 2013 | 04:53 PM
Johnn123's Avatar
Johnn123
Originally Posted by Rpm90001
Zman17,
Read the sticky..I'm not having any issues listed. No oil use,no sark knock,tons of power on hills. What plugs do you think don't look good? They have been in there 77k miles. I'm going to look down in the butterfly's, I have to change the timing cover gasket. I will check it when it comes apart. Thanks for the help.
G
If you have to do that may as well do plenum, rest of tune-up stuff, new o2 sensors, possible cat and a good double roller timing chain. Gonna be there so might as well, save the job of taking it apart multiple times. You're gonna have to anyways down the road now if you don't.
Old Aug 18, 2013 | 07:15 PM
Tensioner doesn't compensate for a stretched chain, it just stabilizes the timing as the chain stretches, instead of letting it bounce around by however much slop is in the system. The chain is still stretched, and timing will still be off..... but, with the double roller chain, it will only really stretch a degree or three.
