Help! Have AC problems.
Old Aug 20, 2013 | 06:07 PM
ldc1969's Avatar
ldc1969
Default Help! Have AC problems.
Hello, I am new to the site and was wondering if someone could help me. I have a 98 dodge ram with a 5.9 and just replaced the heater core and A/C evaporator! I took the truck in to have the A/C charged and the mechanic said it would not take a charge and that the high pressure side was peaking at 450 psi! He said that there is a blockage somewhere and thinks it could be the orifice tube. I replaced the tube and took it back to the shop and they said the same thing, high pressure side is peaking at 450 psi and it will not take a charge. I have taken everything apart and blew air through every part of the system and I can not find any blockage! Any ideas what I should do next?
Thanks
Chuck.
Old Aug 20, 2013 | 09:26 PM
Try a different shop?
Disconnect the lines from the compressor, blow air thru the entire system. Make sure you get some flow. Might be bad compressor.....
Old Aug 20, 2013 | 10:20 PM
ldc1969's Avatar
ldc1969
Compressor is only a year old. Blew air through everything. What would make the high pressure side go up to 450psi?
Old Aug 20, 2013 | 10:49 PM
AtomicDog's Avatar
AtomicDog
Valves in the compressor can be bad/defective, regardless of the compressor's age. If you are able to blow thru all other parts of the system OK, chances are you have a bad compressor. If the compressor is just a year old, perhaps you can exchange it under warranty..
Old Aug 20, 2013 | 10:55 PM
ldc1969's Avatar
ldc1969
So would a bad compressor make the high pressure side go up to 450 psi when charging the system?
Old Aug 20, 2013 | 11:42 PM
AtomicDog's Avatar
AtomicDog
Possibly - if the compressor is still under warranty, its worth swapping it out, since seems you have checked out the other parts of the system
