A/C Evaporator Drain Hose
Old Aug 20, 2013 | 10:53 PM
Fubba's Avatar
Fubba
Default A/C Evaporator Drain Hose
I've got a 94 2500 diesel, and my evaporator drain is leaking into the cab on the floorboard. I got under the passenger side of the truck and noticed the metal port coming through the firewall, however, there is no hose to direct it down in front of the firewall. Do you guys know what size hose goes on the port?
Old Aug 20, 2013 | 11:37 PM
dhvaughan's Avatar
dhvaughan
there is normally no hose.
seal the crack in the firewall around the pipe with black rtv, and poke out any obstruction in the pipe with a wire or wire tie.
if you feel like you need a hose, its about 7/16 - 1/2"
Old Aug 21, 2013 | 09:45 PM
Spillage's Avatar
Spillage
I'll confirm 5/8" ID hose fits nicely.
