check valve??????
Old Aug 24, 2013 | 02:36 PM
lsky6969's Avatar
lsky6969
Exclamation check valve??????
ok i have removed the check valve replace crank position sensor,tps did all trans work change fliulds etc...... still have erratic shifting...... need help !!!!!
Old Aug 24, 2013 | 08:16 PM
What are you driving?
Welcome to DF.
Old Aug 24, 2013 | 10:03 PM
lsky6969's Avatar
lsky6969
1999 dodge 1500 laramie 4x4 5.2l
Old Aug 25, 2013 | 09:21 AM
Adjust the bands? Inspect governor pressure solenoid for clogging? What exactly is it doing?
Old Aug 25, 2013 | 08:34 PM
ryan0714's Avatar
ryan0714
i was gonna suggest looking at the pressure solenoid also. depends on the mileage the bands could be off also like hey you said. you might also look into adjusting the TV cable and see if it makes a little difference.
